Revit to Robot 2015 wait while windows configures Revit Structure
I am working on the integration between Revit 2015 and Robot 2015, currently just on a very rought test model, purely to work through a few problems I have personally had.
The Revit to Robot export works fine, but whenever I try to update the Revit model, (whether I am exporting from Robot, or importing within Revit) I get a windows pop up saying:
Please wait while Windows configures Revit Structure 2015.
This never completes, nor can it be cancelled, and while it exists I can't do anything with the Revit - Robot links. THe only way to remove it is by restarting my machine, even closing both affected programmes doesn't clear it.
This happens every time I try and link any Robot model to Revit, and weirdly sometimes when doing connection design in Robot, without Revit even open... I have tried unistalling and reinstalling but hasn't fixed.
Any suggestions?
sureshchotrani
Wellcome to the community:)
That error is coming as your Revit software hasn't installed properly.
Will request you to uninstall software via control panel & reinstall fresh via setup file which starts from extraction.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
