Add rebar in revit extensions
napooil
napooil
Hi everyone.
Can i add Reinforcing bars in autodesk revit extensions.
Q.jpgwaiting for solution. thank.
sureshchotrani
Below screencast will help you get the answer
Also check here
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
sureshchotrani
Also see below screencast for Beam reinforcement via extension
napooil
Thank you.for your answer.
but if i want add reinforcing bar to database. i can?
A_MAQ
how can i get reinforcement extensions?
Autodesk Expert Elite
