revit to plant3d
MKK20
revit to plant3d
MKK20
How I can import revit model in plant3d with (specifically assembly) properties, so that I can excess those properties in plant3d...like in my case I have model all support (converted into an assembly) in revit and pipe routing in plant3d
how can I use support model in plant3d so that I can generate arrangement drawing from plant3d
MostafaElashmawy
open a 3D view in Revit then export as CAD. while exporting, make sure to choose exporting solids as 3D ACIS
Mostafa Elashmawy
MKK20
Thank you Sir,
I have tried your solution but didn't get properties in plant3d.
I want assembly name to come in properties, plz find attached image
MostafaElashmawy
Unfortunately, the assembly name and properties will not be exported.
You can make your assembly as a family. in that case it will be exported as one set.
Mostafa Elashmawy
MKK20
how can I make my assembly as a family
MostafaElashmawy
You should model it as a family from the beginning.
OR
Isolate it in a 3d view, then export it as a 3d cad, then open a new family and import the 3d cad of the assembly.
then save this family and use it wherever you want in the project so when you export the full project it will have the family name.
However, this may save the name but not the properties.
Mostafa Elashmawy
