How to export sheet containing multiple views in revit
yeLY6SC
yeLY6SC
Hello guys,
I'm trying export sheet containing multiple views in Revit to a .DWG file.
The problem is that I arrange the views in a specific order in the sheet in Revit, (as shown in figure 1).
and when i export the .DWG file the order of the views gets messy as shown in figure 2.
What should i do to keep the views in the same order as I arranged them in the sheet in Revit?
Thanks a lot:]
Did you open the Paper Space tab of the drawing? Looks like you are in Model Space.
MostafaElashmawy
Revit Sheets are equivelant to Autocad Layouts, so when you export a revit sheet you can find it in the autocad layout exactly as exported. but in the model view, unfortunately, it will never follow the same order.
Mostafa Elashmawy
