REVIT to ETABS importing using IFC file Format.
faisalkhttk88
faisalkhttk88
Revit Version: 2020
ETABS version : 18
Hi, I want to import a model from Revit 2020 to ETABS 18 by converting the file first to an IFC file format. The import just works fine however, In ETABS, there is no proper connection between the two.
Below I have attached a snip of how it looks like in ETABS.
Ahmed_M_Heteba
I recommend you use 3rd party tools instead of IFC here is one:
https://apps.autodesk.com/RVT/en/Detail/Index?id=6445397651322878159&appLang=en&os=Win64
also there is CSI X REVIT
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
