Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit templates
1 REPLY 1
320 Views, 1 Reply
Revit templates
Good Morning,
I have a question about the Revit templates. Is there a way where you started a drawing, and lets say you used the metric template and you want to change it to imperial without losing your drawing that you already started?
1 REPLY 1
sureshchotrani
Type UN change the format of units from metric to imperial, for Length-mm to feet fraction inches, Area-mm2 to Square feet & Volume mm3 to cubic feet.
This will change the units of project:)
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
