Revit takes too long to export sheets
jose.almeida
jose.almeida
I'm currently working in a model with 58 sheets, everytime that I send a revision I need to export the sheets to DWG and DWF. This process takes too long (about 120min for each format, therefore 2min/sheet * format).
Is this normal or am I doing anything wrong?
Thank you.
CADmonkey_UK_Building_Services
What are your PC specs?
What size is a typical output DWG?
Can you post a PDF of a typically-complex Sheet?
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
YarUnderoaker
I noted that if project uses a links to Revit's file that has many instances (100-200), then the export process is significantly slowed down.
