Revit Structure IFC Export to open in Robot - Beams rotated
Message 1 of 1
I'm having a problem with Revit IFC export. I'm working on a research where I have to transter a Revit Structure Model to Robot Structural Analysis via IFC (open interoperability, etc). When I work with the direct link between them (RVT to RSA add-on), it works perfectly. However, this transfer made by IFC gives me rotated beams, as shown in the picture attached. Observing the rotated beam properties, IFC seems to confuse dimensions (base becomes lenght and vice-versa).
I've been working on several different parameter sets in IFC export into Revit (Includind IFC Export Classes, different IFC Export Setups and IFC Versions), but nothing seems to work. Also, loads and support conditions are never exported this way.
Does anyone have a clue of what goes here?
Thanks!
Replies (0)
