Revit structural connections modify parameters dissapearing
JANSEN7777
JANSEN7777
Hi, i'm trying to modify an structural connection but when i click on modify parameters (for the connection), this one menu dissapears almost inmediatedly, it gives no time to change the parameters required, i don't know if this is an installation issue or a configuration issue.?
thanks for your help in advance
Orsolya.Balazs
Autodesk Support
Autodesk Support
Hi @JANSEN7777 ,
Do you see this effect on a specific computer or is it not depending on the environment. Would it be possible to send me a small sample with some instructions on which elements you run the command to see the exact context.
Thank you in advance.
Orsolya Balazs
Product Support Analyst - AEC
Autodesk, Inc.
JANSEN7777
Hi, it seems to be that a module (Leica Cloudworks), was causing the problem because when i turn off the point Cloud, the problem stops inmediatedly.
so i think we could close this issue.
Orsolya.Balazs
Autodesk Support
Autodesk Support
I see- thank you for the kind information. I am glad that it has been clarified.
Orsolya Balazs
Autodesk, Inc.
