Hi All,
I'm wondering how to create a Parametric Annotation Family that represents a line with length. I'm using a family to do this because here I can add more parameters to store information.
My issue is that I created an Annotation Symbol:
Then, I created a length parameter "Largo" so the user can manipulate the length of the line and it changes parametrically.
Here is the problem:
As I understand, the annotation symbol works for 1:1 scale, so the unity is depending on which scale the view is, so if I want to put it in a 1:75 scale view and I want the line's length to be for example 100, in the parameter I have to put 1.33333 (= 100/75).
I wonder how to achieve an annotation (or any other parametric object - the simpler, the best) so the end-user just put the length he desires without computing the correspondence.
Thanks in advance for any tip of advice.
Best regards!
