Revit Schedule Appearance.
Hey Guys and Gals,
How can I create the schedule in Revit to look like it does in the Image (no grid inside the schedule but boarder around headers, and no border around title). I figure the title doesn't need to be in the schedule can can just be a bit of text.
Also, can these schedules be set up to only include information on the sheet it appears on? I do not want marked, in this case, columns, to appear on this schedule unless they are on the sheet. Right now they schedule the whole model.
hi, it's better to do it with dynamo
Alan.johnson1970
So if you were creating a sheet for Level 0 columns You could try using Filter by base level and top level
and look in the Appearance options for grid lines / outlines
AJ.
