Revit printing to PDF issue
francfiles
Message 1 of 28
francfiles
We are suddenly experiencing problems with printing to PDF. we tried all Revit versions and all PDF software that we have (acrobat, PDFarchitect and BlueBeam). we never had errors with this software before until last Sunday. now, text and tags are all over the place, and jpg files attached to our title blocks are not printing.
Replies (27)
Message 21 of 28
I don't seem to have any of those updates, and still having the issue since last Friday. The text in the views and in the title block is a mess,  images within the title block don't show at all, and shapes look like outlines without fill
Message 22 of 28
francfiles
if it started happening last Friday, then it most probably caused by the update (i assume)
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 23 of 28
michael.coviello
Autodesk Support
Autodesk Support
Hello @Anonymous
Welcome to the forum and thank you for posting.   I'll be glad to help.
Are you able to run and apply Windows updates?
PDFs printed from Revit have distorted text, incorrect fonts, missing images or other problems
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Message 24 of 28
mauricio_mssf
I Solve my problemm with the DiRoots
If you have issues printing PDF in Revit, please read the information in the link below.
I solved this problem on my PC with DiRoots ProSheets solution.
Microsoft has done some damage with a recent update that created a global issue with many PDF drivers.
https://www.linkedin.com/posts/diroots_prosheets-revit-autodesk-activity-6777854515908554752-ZJOG/
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 25 of 28
francfiles
Thank you for sharing
Message 26 of 28
jnader44KWG
what happened to the autodesk link?  I would rather not download an add-in to fix the issue, but the knowledge.autodesk link from above is dead now and we have people in our company needing a fix.
Message 28 of 28
jnader44KWG
Thank you so much!
