Revit interference check tolerance
Mostafa_R_Ali
Mostafa_R_Ali
According to the tolerance we specify in navis when we performing a clash test, the number of clashes we get changes strongly and not equal to the number we get from revit .
So if we need to get the same number of clashes what is the tolerance should be used in navis?
Or what is the tolerance used in revit for interference check?
anze.kumar
Navis sometimes detects clashes even if you have joined elements in revit or especially if you use the tool "Edit Profile" for walls - see picture below. There is also a different desctiption of clashed in Navis ("Hard",..). I you cannot give any other specifics, I would disregard these types of clashes manully in Navis.
Mostafa_R_Ali
thanks, anze
