Currently have 13 workstations at our workplace. There is currently 3 running windows 10 on them, the other 3 are running Windows 7. Currently have to wait about 3 minutes for a single file to open on workstations running Windows 10. Have tried opening the same file in the Windows 7 computers and they open within seconds. A few things that i have tried are saving the files locally on the desktop. Use the "repair" feature and the uninstall/reinstall. Is there a quick solution to this?
The work station configuration might be working better with win 7
you should consult an it engineer
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Thank you for touching base with us. As @Ahmed_Muharram mentioned, this very well may have to do with configuration of hardware and system optimization. Could you please provide the specifications for a Windows 7 and Windows 10 machine that you are seeing these results on?
Thank you!
Windows 7
- Intel I-4790K CPU
- 32 GB of Ram
- Nvidia K2200
- 256 of SSD
- All Windows 7 updates
- All Autodesk related software updates
Windows 10
- Intel I-9700k CPU
- 64 GB of Ram
- Nvidia P2200
- 1 TB of SSD
- All windows 10 updates.
( Should also point out that the we are getting this issue on the newest computer. Monday of this week was when it got brought in )
@rjebmeier -
Thank you for that information. On the machines that are slow, could you please verify that the regioning for Windows is set appropriately? Please see the instructions below.
Let me know if you see a performance increase after this task.
I just wanted to check in to see if the suggestion above resolved the issue.
If so, please click the Accept Solution button at the bottom of the post.
I have had this problem with multiple workstations old and new out of the box, since windows 10 update 1903
after checking the Use Unicode UTF-8 for worldwide language support the problem is solved on all of them
is says Localeset a mark in Beta, does Beta mean that there is a change the problem will return if microsoft decides to remove this option?
Also can you tell me the rootcause?
this also works without using the beta unicode
> If display language of windows 10 is English other than English (United States) or English (United kingdom) then regional format should be English (United states) or English (United Kingdom). [English (World) also works]
You didn't specify which version of Revit you use, there are some system requirements to run those versions. just say. thanks
It happend on all revit versions so from 2016 up to 2021, and on all sorts of hardware, workstations or laptops form different suppliers. Just a upgrade from windows10 1803 to 1809 or 2020 brought the problem and sometimes not... all had to with if you had more than 1 language installed.(
i found other post on microsoft forums which stated that these problems happend with other software as well so it is not specific autodesk related
