Revit Extensions Doesn't Work ?
aabdelaziz626
Observer Observer
aabdelaziz626
Observer
Observer
i have Both Revit 2017 & 2018
the problem is that the extensions doesn't work for both versions although i re-installed those Extensions Several times .. could anyone help ?
L.Maas
There is not much to go on.
-What is not working? What do you see and not see?
-Have you checked the journal files?
-Try to remove other add-ins
-Can you find the extensions in the add in folder "C:\ProgramData\Autodesk\Revit\Addins\"?
  A file named "Autodesk.RevitExtensions.Revit.addin" should be there
Louis
Please mention Revit version, especially when uploading Revit files.
Hi, I've tried many times to install the Revit Extensions 2018, but it doesnt work. I tried to install via browser download, and via autodesk app. The file "Autodesk.RevitExtensions.Revit.addin" is not there. Where can i download this file, to place manually in the folder?
