Revit Default Parameter language need to change from Chinese to English.
asbalajicivil
asbalajicivil
jay_colcombe
This just looks like you are using Chinese Content/Families
First try opening Revit in the correct region
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-BD09C1B4-5520-475D-BE7E-773642EEBD6C
This may solve the issue but also check what is being loaded into Revit
Go to the Big "R" button and click Options
Then go to File Locations
And make sure that your family files are pulling from the right place when starting families.
(**Probably your C: Drive**)\Autodesk\Revit\Revit_20##\Family Templates\English_I
This will load the default English families for the shared parameters,
Jay Colcombe
Autodesk Certified Instructor
asbalajicivil
As per your instruction its work for entire language change.
but in our revit model some of the defualt parameters only in Chinese remaining its English. for your reference see below.
jay_colcombe
I believe that changes when you change or use a template...the English will be English; French would be French ....etc
So would suggest you Edit you Option in Revit to ensure you are selecting the correct regional templates and families.
Alternatively reinstall Revit and select the correct region on installation
Jay Colcombe
