Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit bending detail not working
7 REPLIES 7
Message 1 of 8
diego.veloso.98
858 Views, 7 Replies
Hi. I'm trying to use Revit bending detail for a specific rebar shape that I draw using free form, but the bending detail image wont work. It's like the image below, the image stays as a exclamation mark.
Thank's in advance for any help !!!
7 REPLIES 7
Message 2 of 8
free form is not working yet as I know we can confirm from @ovidiu_paunescu
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Message 3 of 8
The bending detail is available for free form rebar, only when the workshop instructions is set to "Bend" for the bar.
In this example it looks like the BD can't be computed for the particular bar. It may be related to the large angle between the bar segments (almost colinear)
Can you attach a sample file with this bar?
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 4 of 8
Hi @diego.veloso.98
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ovidiu_paunescu  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Message 5 of 8
Hi ovidiu, sorry for the late reply, didnt see that I got awnsers at my post.
Thats weird, because there`s not any sharp angles in my rebar form. It seems to work when I shorten the length of It, not necessarily removing any curves. The file is attached.
you can see the problem at the first sheet ( DETALHAMENTO LAJE ).
Thank you !!
Message 6 of 8
Hi @diego.veloso.98
Unfortunately there is an issue with bending details not working for bars with segments that are almost colinear. This is due to some tolerances used to define the BD geometry. This will be fixed, but I can't give specific details about the Revit version.
In a simple example, if I sketch a bar from scratch and adjust the angles, the bending detail stops working at about 179.05 deg.
In your case it was 178.854 deg
As a workaround, you could create another section view where you show only that bar, add some text for segment lengths and a tag, and overlap it with the other section, on that sheet.
Message 7 of 8
Thank you, ovidiu ! I was just joing to ask you about that workaround. Cound I, for instance, make that rebar a displaced element but also keep a view of that in place? That would be almost the same of the bending detail.
Again, thank you!
Message 8 of 8
No, because when you displace an element in a view, you only see the displaced element, not the original.
