Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit Base offset
1 REPLY 1
5452 Views, 1 Reply
Revit Base offset
Hello
My base offset is always set to some weird numbers like -4000. When I put the base constraint and then top constraint it gives an error message this is very frustrating.
1 REPLY 1
RDAOU
Hey @Anonymous
It depends on the type of walls you are drawing
If it is a structural wall; it is always drawn in the downward sense...ie: if your current level is Level 3 and you want to draw a structural wall 4 meters high
=> Revit will draw this wall from Level 2 up tol Level 3...therefore you see on your properties pallete: Base Constraint : Level 3 and the base offset is -4000.
  • Once you draw it; you will not see it because it will be below the Level 3 slab.
If you find that confusing...
  1. Use Architectural walls
  2. once done select the walls you need to be structural and check the Structural checkbox in the properties palette.
