Revit 2026 missing connections
- Mute
- Permalink
- Report
Hello, i've modeled the following connection on Revit 2025 using the tertiary plate. Im not sure weather this is the best connection template for a cold formed rafter, but it was the only i managed to get it to work at the time.
This week i tried to model the same connection on a project that was done in Revit 2026 but i quickly noticed that the connection Single Tertiary Plate was missing , as well as some others. I want to assume that this is because the missing connections could be done using a different one? But which one would it be if anyone knows?
I made a custom connection as a workaround but that is not optimal at all as you can imagine.
