Revit 2025/2026: Cannot Use "Add/Remove Host" After Tagging Bending Detail
Hello everyone,
I'm experiencing an issue in Revit 2025 and Revit 2026 related to the "Add/Remove Host" command after applying a TAG to a rebar detail using the "Bending Detail" command.
The issue: After using "Bending Detail" with a TAG, I can no longer access the "Add/Remove Host" option when selecting the TAG. The option is simply no longer available.
It's important to note that in Revit 2024, this workflow worked perfectly — I was able to use the "Add/Remove Host" command even after applying the "Bending Detail" with a TAG.
To better illustrate the issue, I've included an video comparing the behavior in Revit 2024 and Revit 2025, showing how it used to work and what’s happening now.
My question:
Is it still possible to use the "Add/Remove Host" command after applying a "Bending Detail" with a TAG in the newer versions? Was this change intentional, or is it a bug?
I've also attached two comparison images (Revit 2024 vs. Revit 2025) clearly showing the difference in behavior, as well as a .RVT file with the view for anyone who wants to run tests.
Thank you all in advance for your attention and help with this question!
