In my company we use a plan view template in which we have defined a transparency for pillars and walls, so that we can have a cut pattern and a surface pattern visible, to make it easier to identify the elements below.
This works well in Revit 2023, but in Revit 2024 the patters disappear. I've try changing the discipline and i get the patterns but get some halftones in the elements below, so this is an issue with the view discipline.
Is there a way to correct this?
I have come across a similar issue with Patterns and Visibility in Revit 2024 for Structural Applications and logged a support request as it appears to be not acting as expected.
FYI
Nothing to date sorry.
I was hoping that the new update would solve this problem, but it hasn't yet. It's very annoying to have to change the graphics of all the elements individually
