Revit 2024- bar bending detail does not show up on rebar schedule when placed on sheet
mkennedy
Message 1 of 10
mkennedy
I have created a number of bar bending details on one of my section views. I have added the bending detail as one of the fields to be rebar schedule. It shows up as expected on the schedule itself, but is just blank on the sheet I've placed the schedule on. I have gone into the bar bending details options and made adjustments so that it looks like I want it to, but I can't get it to show up on the sheet. I'm sure it's just some small thing, but I've searched everywhere and can't find anyone else having had the same issue.
Replies (9)
Message 2 of 10
veasnakimbitus
Hi @mkennedy ,
I used to made this issue. It should relates to "Schedule Properties".
Please check Filter, sorting/Grouping.
Message 3 of 10
ovidiu_paunescu
Hi @mkennedy
Can you share a model that shows this issue?
You can share it privately to me, if you can't post it here.
It may be that the bending detail can't be computed for one of the rebar. One of the ways to narrow down which one, would be to click the split schedule control, when it's placed on a sheet.
If the resulting parts show the BD still blank, split those as well. Further split any resulting parts of schedule with blank BDs until you get to a single row schedule with blank BD. That is the bar for which the BD can't be computed.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 4 of 10
mkennedy
I switched the bar shape to a different type and it's fine now, thank you. Curious though, if that had been a bar shape that I needed to keep, what about it might/would have prevented the bending detail from being created?
Message 5 of 10
ovidiu_paunescu
Usually an error in calculating the geometry or dimensions of the bending detail (like segment too short, angle close to 180 etc.). The goal is to never see the bending detail column as blank (which is shown as blank if the bending detail can't be computed for at least one bar). This is why I recommended those steps to get to the bar.
Please report any such cases, so we can address them.
Message 6 of 10
emascuka
Hi! I'm having kind of a similar problem... I was working with a large model and I thought I could have messed up with modeling the reinforcement, however I tried with a new simple model for testing and I have the same problem. Perhaps something not loaded on Revit?
I modelled a structural column, added for 12mm rebar, on each corner, and made a schedule. There I get "None" for bending detail (sorry, it's in Spanish):
When loading the schedule into a drawing, still not showing:
Yet, I can see the bending detail on the section view:
I'll attach the file here. I'm certain I'm doing something wrong, but can't seem to identify what, as in every video I see these things go smoothly.
By the way, when formatting schedules, for Bending Image, I have no Field Properties option available:
I'll really appreciate any help.
Message 7 of 10
ovidiu_paunescu
Hi @emascuka
You need to use the Bending Detail field, not the shape image.
To edit the options, once you've added the bending detail field, you can go to formatting and click edit properties
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-E2509B7E-1A01-4597-A11F-562C9B47975E
Message 8 of 10
emascuka
Ok... it was such a simple mistake that I feel embarassed...
Thanks so much Ovidiu for your prompt and accurate response. My schedule now looks way better.
Message 9 of 10
dhanasekaran_natarajan
I have some with the Bending detail. The marked rebar not coming properly within the row height
please advise.
Message 10 of 10
ovidiu_paunescu
@dhanasekaran_natarajan that's strange. Can you provide a sample project showing the issue?
