Revit 2021 Dimensions not performing as expected
ElrinaMills
ElrinaMills
Has anyone noticed in Revit 2021, when trying to add a pre-or suffix to a dimension, that the dialog shows the actual value as 0? The properties of the dimension still display correct, but not in the dialog.
@joan_allen   is this something that the development team is aware of? can we expect a fix in an upcoming update?
If this answer provides a solution, please mark this post as the solution.
Elrina Mills
L.Maas
I see the same. If you have an account you can report it there
See THIS post for nmore info
Louis
Please mention Revit version, especially when uploading Revit files.
