Revit 2019 linked file graphic override problems
jasonr
Message 1 of 26
jasonr
a new problem with Revit 2019
if i link another model in and try to change the display settings in VG projection lines and cut lines to another line wheight like 1 or even 16 nothing happens,
never had this problem with any other versions of Revit
Replies (25)
Message 21 of 26
jasonr
nevermind,
that didnt seem to have and effect on it
Message 22 of 26
Exactly right.  Like Materials, Line Weights are defined by the Link.
Follow this workflow:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 23 of 26
@jasonr wrote:
nevermind,
Why forget it, @jasonr?
Message 24 of 26
eric.zhang305
Try this setting, in the link RVT Link Display Setting, keep Basic tab to Custom. Change the Model Categories to By Host View. You can change the settings without going into the RVT link tab.
Message 25 of 26
eric.zhang305
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Message 26 of 26
r.allen6QR53
I had a similar problem. I couldn't override the color of light fixtures in my linked electrical model. I opened the linked electrical Revit file and opened the light fixture family, looked at the ceiling plan view in the family, and found the lines were actually  a "Detail Items" family. I then went to my view template graphic overrides for the revit link and put in an override for "Lighting," a subcategory under "Detail Items." This allowed me to override the color. This may not be your same issue, but I would suggest examining the families in the linked model.
I also had issue with phase filters. The linked model was not picking up the graphic overrides I had set in phase filters. I found my file and the linked file both needed to be set to the same phase filter "Show Previous + New."
