Revit 2018 PDF/DWG Export issue, double lines instead of single
12:40 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Publishing PDF from Revit Structures with Adobe PDF or to dwg, the drawing comes out with two lines instead of one as on screen. Only for some of the drafting lines i.e. red dash has black as well, blue dash has black line as well (almost as a shadow but a diferent line type). Any sugestions/help? I use Vector output not Raster because raster output brings in other phantom lines not visible on screen in revit. Current export issue is from Revit 2018 but had the same issue in 2017. (For Clarity the red lines on the attachement are from dwg import, completly clean linework with sinlge layer and purged dwg, the blue lines are drafting lines from revit). Thanks
