Announcements
Revit 2017 Steel connections not showing in the type selector
Hi all,
I was trying to do what's been done here: https://www.youtube.com/watch?v=Au9rVvRO8OU
In my own project, when I try to select the "Connection" button, I only see the "generic connection" type in the type selector. The loaded connections from the Structural Connection settings doesn't appear. When I try to just use the generic connection, I couldn't see the green-colored symbols in the video. This is what I get instead:
FYI
1 - I have Revit Steel Connections 2017 installed
2 - I have opened the Structural Connection settings from the arrow on the lower right of the panel, and added all available connections to the "Loaded Connections" box
3 - I tried using our custom Structural steel columns and beam families, AS WELL AS, the out-of-the-box Revit Structural column & framing families 9I used the UC & UB from US Metric)
Not sure where I went wrong. Please help.
Thanks.
Replies (13)
mihai.sandu
Hi Jahzzy,
From what you are describing, my best ques is that you don't have the steel connections visible in the canvas because of the Visibility\Graphics settings.
Please see the following link:
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-021414F2-E8D6-4760-9EE5-6D7E248F4790
Mihai Sandu
Sr. QA Analyst
Thank you, Milhai.
You're right. I forgot to tick all the structural connection boxes. So now, I can already see the generic connection symbol.
However, the steel connections are still not showing. I also can't edit the Connection using the Modify parameters since its greyed-out. I figure it would only be activated once the steel connections are selected.
Again, the steel connections are already loaded, I could even select them from the family browser. It just doesn't show from the type selector.
Any ideas? Thanks again.
Jahzzy
Update:
So I tried to split a structural element, selected the "Connections" button, then the Splice joint in the type selector (it shows up now).
The actual 3d splice joint is nowhere to be found - only the symbol is there, with an accompanied warning (see image below). When I try to click on the Modify parameters, no dialog box pops up.
Not sure what's happening. This is my first time with Revit Structure. Please help.
Jahzzy
mihai.sandu
Hi again,
Most probably the profile on which you try to create the connection is not from an out of the box steel shape.
We created a very comprehensive help documentation for this feature:
Warning messages are covered here:
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-A1EF6B1A-BF7F-435E-9DB3-0577F88C954B
Out of the box steel shapes that are compatible with the Steel Connections feature are covered here:
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
You also mentioned that you don't see steel connections in type selector sometimes. The steel connections are filtered in Type Selector, depending on steel shape type, orientation in canvas, number of input elements,....
This subject is covered here:
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-24C33598-E6B7-426A-ABBD-F0BDFA2EACC1
Mihai Sandu
Sr. QA Analyst
Hi Milhai,
Thanks so much. That's what answered my questions. Just some follow-ups though:
1 - Would it be possible for us to create a modified family based on the existing Certified Steel Shapes and still be able to use the Steel Connections feature?
2 - I couldn't change the Generic connection color (from green to another color) in the VG Filters tab using the Code Checking Status Parameter and/or the Approval Status as stated in this page: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
(Generic connections can display in drawings and use colors based on approval and/or code checking status parameters for an easier review/approval workflow.)
Is that the correct way to change its color display?
Jahzzy
I realized I could only change the symbol color from the Object Styles. The Filters tab can also be used for the Steel Connections objects (not symbols).
- Is that correct?
Hi
See the attached picture.. I am facing issues for seeing the actual connection details everything is turned on...
macky11
Observer
Observer
Try changing the Detail Level to Fine.
Did that so many times, but didn't succeed yet
Hello Mihai,
Please help...we have the same problem but mine the steel connectors won't load. https://postimg.org/image/60afs1ag5/
But when I tried to go to the connection settings I can find the steel connector.. https://postimg.org/image/orcd2kfet/
But unfortunately it won't appear to he properties panel. Only "Generic Connection" is available.
Thank you very much for the help.
Did you try changing the detail level in the lower left of the workspace to "detail level:Fine"
I was having a warm time until I changed it.
IZUCHUKWU.ANI.243359
Community Visitor
Community Visitor
Thanks @Anonymous. you are a saviour!. i have been struggling with this for days now.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
