Revit 2017 - No New Structural Connections
bjur
Message 1 of 77
bjur
So I'm running the new Revit 2017 and with eager antisipation, went straight for the new Structual Connections feature....nothing.  Only the generic connection object is listed.  I tried loading any familes I could find, but they don't show up as new structural connection objects.  I think the ones available to load are the old style, not the newer ones that interface with Advance Steel 2017.  Any ideas?
Accepted solutions (3)
Replies (76)
Message 21 of 77
floreai
One of the causes for your issue might be the connection inputs ( columns/beams ). The detailed connections work only on Revit certified families. Please see this section from online help: http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
Message 22 of 77
floreai
YarUnderoaker wrote:
3) Is that will be public API to make own addon for steel connections?
The API for connection Macros is not available.  The SDK for Connections macros for 3rd parties is available as part of Advance Steel (but not available for Revit yet).
The API for Generic connection and the support of the Revit/Approval workflow is available as part of the standard Revit API.
Message 23 of 77
So, I download Bulding Design Suite 2017, download the connections add-in and fire up Revit to try it out. No joy, all I get is "Invalid connection input". Apparently this means I am using non-certified framing and column members but I just loaded them from the UK content library, so what's wrong?
I'll tell you what's wrong - on further investigation the whole Revit 2017 UK content library is all dated January 2012, I wondered why it said it was upgrading everything from "Revit 2013 - preview" when I loaded the families. One of my colleagues has upgraded their Collaboration Suite and this has the correct library packaged with it (files all dated Jan 2016) so I have fixed the issue by copying their library across.
So, Autodesk, you need to sort out the UK content library that is packaged up with the Building Design Suite Premium.
One other thing - how do I change the bolt diameter selection in the connection parameters to metric?
Message 24 of 77
YarUnderoaker
I guess that all national parts of content library is obsolete.
Message 25 of 77
 I don't think so because the correct UK library has been packaged with Revit in the "Collaboration Suite", just not in the "Building Design Suite".
Message 26 of 77
YarUnderoaker
Message 27 of 77
L.Maas
I had similar issues that some templates and families were from older libraries. As I was early with downloading the files it contained some older files.
Apparently Autodesk updates the download files when they find issues. I have not verified it, as it is of no major concern to me, but redownloading the installation files might help.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 28 of 77
Rivera-Artes
we have problems to understand the code checking tool, the shear imput shows a VR option we will like to understand where and how is calculating process is refering, see image.
William Rivera,
BIM Manager
Silman
Message 29 of 77
@Rafal.Gaweda wrote:
Addin mentioned here :
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-2E50EE74-BEE4-452F-8E92-4F74BC145EED
is called Autodesk® Steel Connections for Revit®
It should be available on Autodesk Account for subscribers soon.
Hello RAfal,
the plug-in is there and I've installed it, but still it doesn't contain any STructural connections inside
is it not ready yet for Subscribers? HOw bout if it's educational version?
BIg Thanks  🙂
Message 30 of 77
Rafal.Gaweda
Autodesk Support
Autodesk Support
See post 16 and 20
Rafal Gaweda
Message 31 of 77
dear
why i not see that
i get onlt that no update for now
Message 32 of 77
Hi there,
I have just upgraded to Revit 2017 and am hoping, as a subscription user, I can have access to this steel connection tool.
Is anybody able to direct me to where the add-on/update for the steel connections actually is on the Autodesk app store?
It seems very difficult to even search for it...
Many thanks.
Message 33 of 77
Joe.Charpentier
The Steel Connections for Revit addon is not available through the App Store.
The Steel Connections for Revit addon is only available through the "Autodesk Desktop App".
You can find it by searching in the start menu, or under All Programs>Autodesk>Autodesk Desktop App
Joe
Message 34 of 77
KirkBricker
Thanks Joe.
I was lost on how to install this feature, and so was my software reseller. All my reseller could say is it should be in your subscription account area.
Thanks again,
Kirk
Message 35 of 77
LyleHardin
I was getting the missing .dll error too. I can't install the 64 bit Microsoft Access Database driver because we have 32 bit MS Office on our 64 bit machines. Revit just keeps crashing when I try the Connections feature.
I did uninstall and reinstall the 32 bit MS Access Database thing and now Revit Connections seems to kind of work. I say kind of, because it no longer crashes. It inserts something with a warning sign. I click the warning sign and I get an "Invalid connection input" warning.
It's a simple clip angle on a W14x145 beam connecting to a W14 column.
Message 36 of 77
LyleHardin
Update. I'm able to get some connections working. I guess it depends on the type of connection you use with the type of steel it's connecting. The clip angle worked on two horizontal beams, but not on a beam going into a column.
Message 37 of 77
LyleHardin
@Anonymous wrote:
So, I download Bulding Design Suite 2017, download the connections add-in and fire up Revit to try it out. No joy, all I get is "Invalid connection input". Apparently this means I am using non-certified framing and column members ...
I'm getting the same message. I'm using U.S. shapes (W14x145, W12x26, etc.). Sometimes the connections work sometimes not. For instance, I can do a clip angle on two intersecting beams, but not on a beam connecting to a column even though the connection preview shows a situation exactly like I'm trying to apply it on. Impressive when it works, but frustrating when it doesn't.
Message 38 of 77
Rafal.Gaweda
Autodesk Support
Autodesk Support
Please post example model with "not working connection".
We will check it.
Rafal Gaweda
Message 39 of 77
please put a link to the add on please...cant find it
Message 40 of 77
floreai
The Steel Connections add-on can be found on your Autodesk account, in the Updates section or Revit section. You can access it via your "Autodesk Desktop App".
Best regards
