Revit 2017 - No New Structural Connections
bjur
Message 1 of 77
bjur
So I'm running the new Revit 2017 and with eager antisipation, went straight for the new Structual Connections feature....nothing.  Only the generic connection object is listed.  I tried loading any familes I could find, but they don't show up as new structural connection objects.  I think the ones available to load are the old style, not the newer ones that interface with Advance Steel 2017.  Any ideas?
Accepted solutions (3)
Replies (76)
Message 41 of 77
Autodesk Desktop manager? What is the name of the App? I can not find it, looked for it everywhere, on App store, on Autodesk account.
Message 42 of 77
Joe.Charpentier
The Steel Connections for Revit addon is not available through the App Store.
The Steel Connections for Revit addon is only available through the "Autodesk Desktop App".
The  Autodesk Desktop App is installed with Revit 2017 (and other Autodesk 2017 products).
You can find it by searching in the Windows Start Menu, or under All Programs>Autodesk>Autodesk Desktop App
Joe
Message 43 of 77
I have experienced some issues and I found out the imperial content & template from Autodesk work better with Steel Connections for Revit.  I have no luck (lots of "invalid connection" warning messages) in a metric project except the Autodesk STR sample house model.
Message 44 of 77
floreai
Steel Connections work only with Revit certified families.
The simplest way to identify if a section is certified is to check in the profile type properties if it has the parameter "Section Name Key" ( see attached pic ).
Here you can find a detailed list of the certified families delivered with Revit 2017: http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
Best regards,
Irina
Message 45 of 77
Thanks for your reply. Yes, I used all of the out-of-the-box Revit certified family, W-Wide Flange series. What I am experiencing is the steel connection working fine with Imperial template & content but failed with metric template & content. I am going to submit a ticket with file attached soon.
Message 46 of 77
philippe.bonneau
Please have a look at this video:
https://youtu.be/3czl1Zr80qQ
Regards
Philippe
Message 47 of 77
Thanks Philippe. I have watched the video before and understood the process. Attached screenshot is my testing result.  What I experienced is the steel connection works fine with Imperial template & content but failed with metric template & content. Most annoying thing is when I encountered the "Invalid Connection Input" warning, I cannot modify the parameters. I only can delete it and redo again with some trial errors.
Is there any update or hotfix for this bug?
Message 48 of 77
chubbard
When I place the connection I get a Red circle and the warning "Invalid connector input." Any idea what this means?
Message 49 of 77
Joe.Charpentier
Could you provide more information about the situations where you get this error?
My first guess would be that you might not be using Certified Families.
Joe
Message 50 of 77
chubbard
That was my initial thought but I made sure to load from the Revit 2017 imperial library, STD wide flange shapes? Other location I should be looking?
Message 51 of 77
Joe.Charpentier
The families that you want to use are in the "AISC 14.1" subdirectory.
More information about which families are compatible with Structural connections is available here:
Joe
Message 52 of 77
chubbard
ok I loaded those families and replaced the previous families, still getting the error. I do see the "Section Name Key" parameter in the type properties, but I did before when I loaded the 2017 families from the main structural directory.
Message 53 of 77
Joe.Charpentier
Can you upload a model?  It's very difficult to troubleshoot what might be happening without more information.
Joe
Message 54 of 77
I get message "invalid connection input", even I'm using certified families from "C:\ProgramData\Autodesk\RVT 2017\Libraries\Germany\Tragwerk Träger\Stahl" and "C:\ProgramData\Autodesk\RVT 2017\Libraries\Germany\Tragwerk Stützen\Stahl".
But, when I'm using from "US metric AISC14.1", it works well.
Martin
Message 55 of 77
mihai.sandu
Hello Rusand, The certified families contain a new parameter called "Section Name Key". Steel Connections can be placed only on profiles which contain this new parameter. http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3 The families are localized, this means that the parameters are translated to different languages depending on the country of the content. The translated parameters are read by Revit only if the platform is opened in that language, meaning that if you want to use the German Content you will have to turn Revit's language to German. In order to change Revit's language to something different then English, please see the following page: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2016/... So if you want to use the German content you will have to turn Revit to German language. The English content works correctly on your side because Revit is in English and the "Section Name Key" is read when you "Insert" the family in the project. Hope this answered your question, Mihai Sandu
Mihai Sandu
Sr. QA Analyst
Message 56 of 77
mihai.sandu
Hi again Martin,
The English version of the European specific steel shapes (which you can use in Revit - English) are located inside the following country folders:
Belgium, Finland, Greece, Netherlands, Norway, Romania and Sweden. After you install the content of this countries the European shapes can be found in:
C:\ProgramData\Autodesk\RVT 2017\Libraries\"Country"\Structural Framing\Steel\Europe Specific
C:\ProgramData\Autodesk\RVT 2017\Libraries\"Country"\Structural Columns\Steel\Europe Specific
Hope this answer solved your issue.
Mihai Sandu
Mihai Sandu
Sr. QA Analyst
Message 57 of 77
Thank you Mihai, it works well and I have now all steel profiles I need for my work.
Message 58 of 77
Hello, I have problem with families in folder Europe specific (country Finland) because some families missing (like SHS EN 10210-2 Column). I had reinstall revit last week and now some families missing. What could be wrong?
Message 59 of 77
mihai.sandu
Hi Rusand, I found the following link that may help you to install the Finland standard content properly. https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles... Regards, Mihai Sandu
Mihai Sandu
Sr. QA Analyst
Message 60 of 77
I already downloaded it and install steel connection app. But, after load connection into project,( Pls see attachment)
I don't see steel connection in properties panel.
The connection just appear in type properties.
I already tried to uninstall and reinstall some times, but up to now, I can't solve this matter. Please help me this.
Many thanks.
