Revit 2016
Revit 2016
david
Observer Observer
Message 1 of 9
Revit 2016
david
Observer
Observer
I can't export or import dwg files into / out of revit 2016.
any fixes available for this?
Replies (8)
Message 2 of 9
A_MAQ
does it give you any error message ?
or the import button is grayed out?
Autodesk Expert Elite
Message 3 of 9
david
Observer
Observer
Hi A_MAQ,
no, no error messages or greyed out boxes.
dh.
Message 4 of 9
A_MAQ
so what do you mean by that you could not import dwg?
what is the case ?
Message 5 of 9
david
Observer
Observer
while in a 1:20 drafting view I click Import Cad (insert menu)
dialog box opens, I select the .dwg file, click open and nothing appears (after zoom extents)
also tried linking the same cad file - same result.
screengrab of dialog box attached
Message 6 of 9
A_MAQ
did you try to change the units while you are working cad ?
try another cad file
Message 7 of 9
david
Observer
Observer
Hi A_MAQ,
didn't try changing units
tried a number of different .dwg files - same negative result.
also tried a dxf - same negative result.
DH.
Message 8 of 9
A_MAQ
try changing this units option
Message 9 of 9
A_MAQ
also after importing dwg go to VV and under imported categories , will you find your file ?
