We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
so what do you mean by that you could not import dwg?
what is the case ?
while in a 1:20 drafting view I click Import Cad (insert menu)
dialog box opens, I select the .dwg file, click open and nothing appears (after zoom extents)
also tried linking the same cad file - same result.
screengrab of dialog box attached
did you try to change the units while you are working cad ?
try another cad file
Hi A_MAQ,
didn't try changing units
tried a number of different .dwg files - same negative result.
also tried a dxf - same negative result.
DH.
also after importing dwg go to VV and under imported categories , will you find your file ?
