Retrieving my 'Model in place > Void form'
Hi
After I use a 'model in place > void form' to cut a roof, how can re-select the void so I can use it to cut another roof? As shown below.
Thanks in advanced.
luis_brionesalonso
You could always make a Schedule that lists the Generic Models in your project and select it from there if you can't manage to select it in your 3D view, although I think it should be possible to just select it there by hovering your mouse over it.
Do you have the Generic Models category turned on in your visual overrides?
Try making a selection that you know would include the generic model (make a selection box from right to left) and use the filter tool to filter out the generic model. Works best if you make sure that the Void would be the only generic model included in your selection.
After you've selected the Generic Model you need to click 'Edit in Place' and use the cut tool to make it cut the second roof.
raza.m.syed
Observer
Observer
Thank you so much for saving my time. This actually helped a lot.
