Request
Request
dessinateur2Y3A6C
Request
dessinateur2Y3A6C
I am a designer in a factory and I use Revit, as you see I just drew the structure manually so I would like to know if there was a plugin to do itCapture d’écran 2023-10-04 115339.png
Accepted solutions (3)
jay_colc
I assume you mean timber panel/framing.
There are a few I know off the top of my head;
Hsbcad
Agacad
Wolf-Horizon
Strucsoft
Also have a look in the Autodesk App Store, here is one from a quick search.
https://apps.autodesk.com/RVT/en/Detail/Index?id=1903216501564457353&appLang=en&os=Win64
Jay Colcombe
Autodesk Certified Instructor
Tom_Kunsman
For the roof beams you can use the Beam System tool. That will help speed up modeling of that. Could even use it for the wall framing.
Generally I don't model the wall framing. Where you required to model it for some reason?
The picture does look good. With time the modeling should get faster as you get used to working in the program. "Hard work does pay off" and you can't automate everything.
jay_colc
Yes you can use Beam System for Vertical Framing Elements but make sure you use Grids as otherwise there are lots of Reference Planes required.
I have also seen Curtain Walls used in an affective manner too as you can edit the Gridlines so a little more flexibility on layouts and utilise horizontal mullions for noggins and Top/Bottom Plates
Jay Colcombe
dessinateur2Y3A6C
how to get elevations (framing elevations) in revit properties as in your photo
jay_colc
You create a reference Plane and SET this as the plane to draw the Beam System on.
I would suggest using Grids instead as they serve the same purpose and can be used for framing and attaching elevations etc.
Jay Colcombe
