Replace "Varies" in floor tag
klas.bosaeus4MAFN
klas.bosaeus4MAFN
Hi
Im not great at writing syntax and have trouble creating a floor tag that gives another word for "Varies" when the elevation differs along the floor. English is not our drawing language and it would be nice for this "Varies" to be replaced with at swedish word. I´ve tried creating a calculated parameter and writing an IF statement in different ways but the problem seem to be that revit can not detect "Varies" in that statement.
If I put "Varies" in brackets I get "improper use och boolean expression" and if I don't use brackets it says that Varies is'nt a parameter.
Any ideas?
ovidiu_paunescu
Hi @klas.bosaeus4MAFN
This is possible starting with Revit 2022
Here's more info about that https://www.youtube.com/watch?v=NJHjFqYfNAc
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
ArmanMargaryan
I hope I was able to understand and help you correctly.
See attached link.
https://autode.sk/3eW7h0q
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
ArmanMargaryan
Sorry, I didn't see that you have already answered.
Arman Margaryan
Linkedin | Facebook
klas.bosaeus4MAFN
Thanks for the help, thats nice to have that option oob in -22, i'm working in-21 though. Isn't there a way to call for the parameter value "varies" in an if statement? Like IF (Elevation at Bottom Core="Varies"......)
ArmanMargaryan
Unfortunately you cannot change this parameter, other than switching the language.
See attached files.
https://forums.autodesk.com/t5/revit-ideas/revit-varying-rebar-sets-change-text-quot-varies-quot-to-...
https://forums.autodesk.com/t5/revit-structure-forum/revit-varying-rebar-sets-change-text-quot-varie...
Arman Margaryan
Linkedin | Facebook
ArmanMargaryan
If the above reply answers your question; Please mark it with ACCEPT SOLUTION.
Arman Margaryan
Linkedin | Facebook
