REPEATED REQUEST: Still wrong rebar sketches compared to modelled
semi
semi
yet another remark from our contractors why the shapes STILL dont match the rebar models:
please FIX this error!
jay_colcombe
Obviously we have established if you place Schematic Bending Detail in the View or Workplane in which the Rebar was placed/drawn it will allow you to Modify the Tag to the Correct Orientation but this is MANUAL an not AUTOMATED as per the Realistic Bending Detail which could be your main gripe?
In the opposite direction to Placement you have your issue and the editing of the Properties does not resolve your the point raised!
HOWEVER, in 2026 you can Flip the direction of the Rebar
This has the following influence of the Schematic Bending Detail in an opposite placement View and gives you a solution without the need to ALWAYS create the correct View orientation as per the top image
Not as good as getting to act the same way as the Realistic Bending Detail but a workaround for now but not sure how practice it is as it influences the A & B length values?
Jay Colcombe
Autodesk Certified Instructor
