Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Render to printer shows partial picture
7 REPLIES 7
Message 1 of 8
chriskD6WP2
337 Views, 7 Replies
Whenever I render an image to printer, I never get a full picture. Here is an example of what happens. Any suggestions?
7 REPLIES 7
Message 2 of 8
L.Maas
in reply to: chriskD6WP2
Not seen this before
-Memory limitations?
-Hard disk space?
-When render is made, does that part render at all?
-What happens when rendering at lower resolutions?
-What happens when redering another view from other position?
-Does it happen in all projects?
-Have you tried it on a different computer?
-What happens when you render with a different Revit version?
-Have you looked for updates (Revit, OS)?
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
chriskD6WP2
in reply to: L.Maas
1. 64 GB RAM
2. 300+GB of free space
3. That part renders but at the very end when I get the final screen, I get the black area. The black area is not always in the same spot. It depends on what picture I'm rendering.
4. Same thing at lower resolutions.
5. It does not matter the view or position. I will get some blacked out area in the picture.
6. All projects.
7. Will try it on another computer.
8. Only have the one version 2021 installed.
9.  Have the latest updates.
Message 4 of 8
Save to Project or Export after Revit finished rendering.  Does the black area still show in the saved image?
Message 5 of 8
chriskD6WP2
Yes, it shows up in the saved image.
Message 6 of 8
L.Maas
I would try:
-Install Revit 2022 and try it there
-A Revit repair or reinstall.
Louis
Message 7 of 8
chriskD6WP2
Just noticed a patch came out yesterday. Will apply and see if that fixes the problem. Will also see if 2022 or a repair/reinstall fixes the problem.
Message 8 of 8
chriskD6WP2
Installed the patch and did a repair. This seemed to have fixed the problem.
