Remove Hidden Lines not working
chriskD6WP2
Message 1 of 18
chriskD6WP2
I know I've asked this before but I can't find it in a search. Whenever I try to use the Remove Hidden Lines button it doesn't do anything. Could I have some graphics override turned on?
Thanks!
Replies (17)
Message 2 of 18
hmunsell
is your view set to Wire frame?
Howard Munsell
Message 3 of 18
chriskD6WP2
Yes.
Message 4 of 18
Show Hidden Lines under the view's properties must be set to By Discipline.
Message 5 of 18
chriskD6WP2
Here's a screen shot.
Message 6 of 18
MostafaElashmawy
you should click the remove hidden line button then select the element that will hide the hidden lines then select the element with the hidden lines to be hidden.
Mostafa Elashmawy
Message 7 of 18
chriskD6WP2
That's the problem, it's not working...for me. 🙂
Message 8 of 18
Try Coordination or Architectural with Show Hidden Lines set to by Discipline. Remove Hidden Lines does work with Structural and MEP Discipline.s
Message 9 of 18
hmunsell
if your view IS set to Wireframe, set your view to Hiddenline.
is the issue that you can not select the elements to "To Hide Others" and "Be hidden", or can you select them but it is not removing the hidden lines?
Howard Munsell
Message 10 of 18
chriskD6WP2
I had set my view to Hiddenline but then back to wire Wireframe to do something else.
I can select the objects when the hidden lines stay then do not disappear.
Message 11 of 18
hmunsell
can you post the file or eTransmit it and post it?
Howard Munsell
Message 12 of 18
chriskD6WP2
Here is the model.
I'm sure it's something I'm doing wrong. Ha!
Message 13 of 18
hmunsell
i assume(d) the Section 9 is the view in question?
  • VG
  • Structural Framing
  • uncheck Hidden Face
Howard Munsell
Message 14 of 18
chriskD6WP2
No, it was the t.o. platform structural plan. It had Show Hidden Lines set to By Discipline. Once I changed it to None, the hidden lines disappeared.
I knew I missed something.
Message 15 of 18
Of course if you changed Show Hidden Lines to None then all hidden lines will not show. I thought you only wanted to remove selected hidden lines, not all of them. Oh well...
Message 16 of 18
chriskD6WP2
Yes, I only wanted to select only some hidden lines to remove but at this point, I'd rather just remove them all than try and figure out why I can't select just some.
Message 17 of 18
Because the Discipline is Structural. Remove Hidden lines tool only works with Coordination and Architectural views set to Show Hidden lines by Discipline.
p/s: I realize I made a typo in post #8. It shouold read: "Try Coordination or Architectural with Show Hidden Lines set to by Discipline. Remove Hidden Lines does NOT work with Structural and MEP Disciplines."
Message 18 of 18
chriskD6WP2
For some reason, I didn't try this suggestion. I must not have seen it but setting Discipline to Coordination or Architectural worked for me. I wonder why Structural doesn't work?
Thanks!
