Reinforcement not visible
SabinaK4RXQ
SabinaK4RXQ
I have rebar connecting base slab and column. These connecting bars are not visible in floor plan, even though view range is OK. Are there any ideas how to fix this?
Thank you!
jay_colc
Have you checked they are not Hidden or or Filtered Out?
Rebar elements that are cut by the cut plane are always visible. [Visibility States] has no effect on the visibility of these rebar instances.
Are there any plan regions in place?
Known issue previously where the plan region was only at a small part of the plan, but some sort of bug messed the rebar visibility up
Rebars not visible in view when a plan region is in view in Revit
Jay Colcombe
Autodesk Certified Instructor
SabinaK4RXQ
It was obscured (in view visibility states), which I then checked, but it was still not visible on the floor plan. Then I checked Sofistik's assignment to the selected sheet, and rebar went to visible. Thank you!
jay_colc
That’s the problem with addins they often use similar features which override the Revit ones and leave you bemused as there is another level of filtering and visibility to consider
Jay Colcombe
