Message 1 of 9
Hi.... I am posting this in the hope that we can get some support from Autodesk to resolve problems with the rebar UK shape code family (shape code 98) which doesn't seem to be currently available ?
I have just modelled a project where I needed a shape code 98 but it was not available in Revit. I was able to use a multi-planar bar in it's place with both end legs projecting in the same direction (rather than opposite directions) and name it as shape code 98 which meant that the bar schedule was generated correctly but then had to modify my drawings manually to detail it correctly.
Is there a valid reason why shape code 98 is not available or am I just missing something ?
