Gud morning all . This is a dowel bar using in precast construction. I need to maintain the crank length (300mm) and offset (50mm) constant throughout the project .The value 790 is adjustable parameter .In revit case rebar family behavior is so flexible. So I can't lock the length values .how can I make this ? If anyone has answer please answer me.t Thanks
Hi James
If I put formula in structural rebar parameters, it couldn't load into project (the load into project option goes fade off ). Really it's frustrating 😣
I'm knowing nothing about either dynamo nor programs.in fact I'm a nobie to revit
Hi
Give me a few days to upload a pluggin, which allows you to convert to rebar container. If you want more structure plugins, you can download them from here:
@Anonymous currently you cannot lock any of the dimensions of rebar, when using shape driven bars.
You could sketch the bar and set the geometry to free form. This will create a bar that won't react to anything.
After finishing the sketch, you can change the Workshop Instructions to Bend. This will match it to a Revit rebar shape and report the segment lengths.
If a matching shape isn't loaded, it will be created.
@jamess166 i would recommend you look at free form rebar as well, for your plugins. It is more versatile than the rebar container.
Is there a chance to set the locked length for shape driven rebar in 2024 version? It still does not allow to set equation for doímension parameter, nor leaving the dimension without parameter.
Any chance also to be able to place the set of the rebar in the direction that is not perpendicular to the plane of rebar shape without adapting it by variable rebar set and selectin appropriate constrain planes.
What about alowing rebar on trajectory not ponly for walls and slabs? And maybe allow setting the direction of rebar so it is not only perpendicular to selected trajectory.
Petr
One more question, if I use the free form rebar wotkaround, the shape is locked and can not be swapped for another shape that would for example have different legth of some segments. The only possibility to addapt this rebar is by editing constraints, but this possibility in Revit is very limited.
Petr
