Rebar Solid View
Rebar Solid View
Message 1 of 21
Rebar Solid View
Good Day EveryOne !!
so i make a rebar of column, then i make a filter so the rebar will have a colour.
i go to 3d view, but i found the rebar still in lines, then i click the rebar, click "view visibilities states" then i check the
view unobscured and view as solid.
ok now my rebar looks good. but when i try to copy my rebar, the copy not in solid.
how to make a filter so all my rebar can view as solid, so i dont need to click them one by one ?
the original have a solid view and color, the copy does not have anything :(the original have a solid view and color, the copy does not have anything 😞rebar warna 2.PNG
Replies (20)
Message 2 of 21
Luiscko
You need to check if you have the fine detail active maybe you do not have this.Another thing that you can do is modified directly in your visibility graphics put allway detail fine and solid elements, other thing is using and easy script for Dynamo to apply to all the elements..
I have the process in this video: https://www.youtube.com/watch?v=T3RJqXmljuM
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
Message 3 of 21
shefypattambi
Hi @Anonymous ,
You can use this dynamo graph to make all your rebar solid and obscured in the current revit window. You have to install spring package and dynamo for rebar package to use this graph. also the version of dynamo is 1.3.
Message 4 of 21
ovidiu_paunescu
Hi @Anonymous
The current behavior of rebar requires a manual input whenever you copy the bars, to show rebar as solid.
The unobscured option is checked by default in the view where the bar was created (by placing or copying the bar).
You can make multiple bars at the same time appear as solid.
As @shefypattambi mentioned, you can also use a dynamo script for this.
The Structural Design Dynamo package by Tomasz Fudala contains various tools for rebar, so you can check that out.
You can even configure the script to be used in Dynamo Player, so that you can run it directly from Revit.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 5 of 21
Hi  shefypattambi,
I tried creating above programme to make Rebar Solid in 3D view but I didnt find the SPring package on internet/dynamo search.
if possible can u send me the dynamo programme to my email it will be more helpful to me.
my mail ID: kumarsubramanya.k@gmail.com
Thanks in advance
Message 6 of 21
shefypattambi
Hi @Anonymous ,
You can download the graph from post no 3. Please search "spring" package in dynamo package manager.
Message 7 of 21
Hi shefypattambi,
I tried to create the programme today but some warning came and its not working can you please help me out of this.
I attached image below
Thanks in advance
Message 8 of 21
shefypattambi
Hi @Anonymous ,
could you please show me the warning message by hovering your mouse over the icon on top of the yellow colour node named as "Rebar set solid in view".
Message 9 of 21
shefypattambi
@Anonymous
Try this graph
Message 10 of 21
Hi
Ive attached warning image.
Message 11 of 21
Error while opening zip file
Message 12 of 21
shefypattambi
Pls upload your graph here.  Also mention the package that you are using
Message 13 of 21
Hi ,
Please see the attachments I installed two packages only... Spring nodes and BIM4Struc.Rebar.
Message 14 of 21
shefypattambi
Bim for structure package is replaced by dynamo for structural design
package created by tomaz fudela. You can use that package or dynamo for
rebar package developed by core studio of TT.
Message 15 of 21
Hi  shefypattambi,
Finally Its working ..thank you so much for help.
But we are working on a central file if I am running the programme it is asking for request from other users.
Okay anyway one simple way to make solid rebar. I'll do run the programme once in a day that also will work for me.
Thank you.
Message 16 of 21
raymondsnavarro
I tried this but it has warning. It is also same as your previous post.
Message 17 of 21
guv_singh56
Community Visitor
Community Visitor
can you please tell me how can i view the 3D rebar on BIM 360. We go to the BIM 360 folder-upload and then view the model, but then the rebar is 2D?
Is there a way to over come this?
Message 18 of 21
robertawalker
I do not get the option to view as solid when i go to visibility states
Message 19 of 21
jay_colcombe
This has changed in recent updates/versions and is controlled by the Level of Detail for the View and previously
Help | Adjust the Visibility for Rebar and Rebar Couplers in a View | Autodesk
Jay Colcombe
Autodesk Certified Instructor
Message 20 of 21
novitasukmawati
Community Visitor
Community Visitor
then what is the solution so that it can become view as solid
