Rebar shapes, Placement orientation, Placement planes not visible in revit 2020
datirnayan
datirnayan
When i am trying to place rebars in any structural elements in REVIT 2020, i am not getting options for Rebar shapes, Placement orientation, Placement planes instead i get options like free form, alligned, surface. How can i bring back the previous options?
PavelAnd
Hi @datirnayanIf you select a Rebar in the placement method, then these tabs should appear. If there are no panels, then check if you have the latest update installed. Perhaps reinstalling the Revit will help.
Best regards, Pavel Plotitsyn.
Alan.johnson1970
You need to be in a section or elevation view.
AJ.
PavelAnd
In plan view it's works too.
After your post I checked views and in 3D I get the same problem.
datirnayan
Thank you. It worked
