Rebar Shape Detail command
Hi everyone,
Rebar Shape Detail command is a very useful function that enables you to see exact dimensions and shape of any drawn rebar in 2D view. Unfortunately it is still not implemented in Revit.
....to see more about this function take a look at YouTube video below:
https://www.youtube.com/watch?v=K584pPpdg8k
___________________________________________________________________________
If you want to support this idea please vote on the link below:
https://forums.autodesk.com/t5/revit-ideas/rebar-shape-detail-command/idi-p/7389886
if you see this "shape detail command" idea useful and want it to be implemented in the next Revit version, please give your vote on this link: https://forums.autodesk.com/t5/revit-ideas/rebar-shape-detail-command/idc-p/7419344#M14296
Regards!
Va3ilem
Anyone solve this problem?
probably with Dynamo ...
ipselute
@Va3ilem:This problem has been solved long ago by third-party extensions like Graitec, Sofistik, etc. Autodesk just seems to be hard-setted NOT to implement this (very) useful feature.
Va3ilem
Ok, solved by third-party extensions like Graitec, Sofistik, etc.
So to make a drawing i need Revit + third-party extensions.     2 programs to do one detailing of rebar?!
And when i need to export 3d PDF i need Revit + another third-party extensions
And when i need ..X.. -> Revit + something else third-party extensions.
Actually i can not use just Revit to make a drawing complete to plot. Maybe after 2020 version.
ipselute
Very sad situation indeed. Looks like Autodesk lacks both own will and smarts to do it.
P.S. If it makes any difference to you: neither Autocad can do (smart) rebar detailing.
P.P.S. I just hope Autodesk won't buy Graitec and Sofistik and close them out (as it did with many other rebar detailing software). It would be their doom for eternity.
