Rebar, lock presentation
Hi!
I was wondering, is there a way to lock the presentation of the rebars? Right now im having the problem that when i change the spacing between my multipled rebars in Revit 2015 all the rebars starts showing. Its really anoying to have to change the presentation all over again.
Ahmed_Muharram
You can make the presentation permanent by going to structure tab
then from reinforcement choose reinforcement setting
and then presentation as shown in photos
if it helped you please mark as solution
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Hi and thank you for answer,
in rebar settings as shown in your pictures I can only choose if I want to
show all, show middle or show first and last as standard. It does not allow
me to lock the "select" selection.
The problem only appears when I have used the “select” rebar tool for
presentation and then change something like the height of the wall. So it
does not affect the rebar if it set to “show middle” “show all”or “show
first and last.”
