Rebar in Varying Rebar sets disappears in 3D-views. When not in a Varying Rebar set, rebar are showing again. Same rebar also doesn´t show in a nwc-export.
Someone who has a sollution for this problem?
What version of Revit are you using?
Are all the varying rebar sets not visible as solid?
An issue very similar to this was fixed in Revit 2022.1. Are you able to test in this version?
Maybe you can post a simple example where you are seeing this behavior
Hi
I´m using Revit 2022.1. But the problematic rebar was created in Revit 2021 and then uppgraded to 2022.
It´s not all varying rebar sets that doesn´t show in 3D-views, just some.
I tried to make a new 3D-view. But the rebars disappears when I use the Show obscured-command. If I remove them from varying rebar set, they are showing again.
Are you able to share a sample project with such bars?
