Rebar in column is not considering cover space.
Birju7
Birju7
I have put 30mm cover, but rebar does not consider during fixing time. @ToanDN , @L.Maas @RobDraw
alan.johnson7YLND
Which view did you place the rebar?
Which placement plane did you use?
Which placement orientation did you use?
What rebar set options did you use?
Have you set cover for Top, Bottom and Other?
For example:
If these bars were placed in plan, using Near Cover, and parallel to work plane, with a layout of number with space
you could get this result.
