Rebar Hook 90° length parameters issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
About Rebar Hook 90° Lengths Parameters, as you can see in the image below, the Revit guide's explain that the "Hook Length" must be shorter than the "Tangent Hook Length".
But inside the Rebar Bar Type Properties (last image below), this two parameters have the same value. I tried to remove auto calculate and changing manually the Hook Length, but automatically Revit set the same value to the Tangent Length.
This cause some trouble inside the Rebar schedule between the total length value and the sum of the lengths of singles segments and hooks lengths.
Is this an issue of the automatic calculation of 90° Hook parameters?
In 135° and 180° hooks, these parameters works perfectly according with the Revit's guide.
Thanks for your attention.
