REBAR DETAIL IN CMU BLOCK WALL
ethannavah
ethannavah
I'M TRYING TO SHOW REBAR DETAIL IN CMU WALL IN A SECTION VIEW. REVIT WON'T ALLOW IT ONLY IN PRECAST WALL
alan.johnson7YLND
The wall should be able to host the rebar as long as the wall is structural.
ethannavah
thanks. but i'm showing  at the section cut a repeating detail (cmu block) and i can't make that to be structural
alan.johnson7YLND
Oh you are using a repeating detail?
That will not host rebar, but you can just draw the bars (using lines)
