H DIMENSION ON CURVED REBAR
jschnare
jschnare
THIS IS A MAJOR FLAW OR BUG, AND HAS CAUSED US SOME SERIOUS HEADACHES.
Ahmed_M_Heteba
can you share the rebar shape family
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
jschnare
PLEASE FIND ATTACHED
ovidiu_paunescu
Hi @jschnare
The dimension needs to be placed to the arc and end of arc. To do this, you need to do the following steps:
  • Create aligned dimension from reference plane to arc
  • Select dimension and click edit witness lines
  • Deselect the ref plane
  • Go over the arc end > tab until the end is pre-highlighted
  • Click to place
  • Assign the parameter to the dimension
I've attached a family where this dimension is corrected. This family will be updated in an upcoming version of Revit.
Let me know if you have any questions.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
