Rebar constraints
Rebar constraints
Rebar constraints
Hello guys,
Please i need help in the rebar constraints. When i click on edit constraints, this window show up to me. Any solution please ?
A_MAQ
Hi you can have a look Here to check you are doing it in right way
Autodesk Expert Elite
ovidiu_paunescu
Hello @Anonymous
That beam is cut by each column, producing a cut face.
Rebar cannot currently constrain to such faces resulting from a cut, so the system doesn't select a constraint for that handle automatically, showing that warning.
You can click the face of the column as a constraint target for that handle, or you can leave it without a constraint and drag the end handle to adjust its position.
Faces that can be selected as a constraint target must be part of the host element or its immediate neighbors (other elements joined with the bar's host element).
Let me know if this works or if you have other questions.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Thanks a lot. I am new to revit and BIM and i am trying to read books and watch videos to develop my skills. Any suggestions ?
ovidiu_paunescu
I would recommend you start with the architecture essential training on lynda.com.
It will show you how Revit families, parameters, visibility work. This should be the base for further learning of structural related topics (rebar etc.)
See this forum thread for more learning tips and resources.
so how to select the column face as constraint?
tomasz.fudala
