Rebar Constraint along Reference Planes
maalumauig01
maalumauig01
Constraining a rebar set to reference planes makes a more convenient way of locking a rebar and making changes to the distances of the rebars.
jay_colcombe
Revit uses constraints in the Host as this determines the length on the size of the host as this make more practical sense.  Reference Planes can be incorporated if you use the Splice Rebar Tool
These could also be controlled by Dimensions and EQ (equidistant or Global Parameters)
You can also add you input/suggestion to the Revit Ideas Forum
Allow rebar constraints to custom reference planes, not just to faces of elements - Autodesk Communi...
Jay Colcombe
Autodesk Certified Instructor
